Auto layout - wrapping doesn't work
  • September 1, 2023
  • 4 replies
  • 2393 views
The case scenario I got is having a block of text that is my title and underneath I got a series of images.
If I just use Wrap on the main frame the images won’t stay on the same line. Therefore I created a sub-auto layout with just the images but then they don’t stack anymore when I resize.
See pics
Thanks to whoever understand why it doesn’t work
Best answer by Marian_Brchan
Not sure if this is what you’re looking for but maybe you need to set the horizontal resizing on the image auto layout to fill? E.g.
Marian_Brchan
  • September 4, 2023
Thanks! It works now but I had to remove the auto layout wrap from the main frame otherwise it was stacking them horizontally.
Marian_Brchan
What’s the purpose of the wrap on the main frame? If you want the title to go across (full width), you can use a “regular” vertical auto layout.
  • September 4, 2023
I thought (wrongly) that it was the only way to get the elements to fall down.
