Hi, I’m very new to Figma. I created a loading animation using a tutorial and followed all the directions about creating variables within the component. I’m using delay - change to - smart animate. I made sure the instance is on the object and not the frame. I’ve built it several times and it will not animate in preview no matter what. I have successfully used animate with click through on a different project. Please let me know what i’ve done wrong.
Here is the link to my file.
\https://www.Figma.com/design/Y6yNhMxEEPlqR96sAfbtRp/Loading-Animation?node-id=0%3A1&t=4Ol6ISvMjofC78K0-1
Animation not working at all
Best answer by Vishal_Ramawat
Seems, you have converted the blue arc to vector and that is causing the issue.
You just need to duplicate the outer circle and convert it to arc and it will work fine.
Use the control on the circle (sweep) to make it into arc.
