An Object Inside Of A Component is Stretched On The Prototype
  • December 12, 2023
  • 197 views
Hey, so i have a problem here where i designed a drop down field where the user can add up to 5 more dropdown fields. the main component works perfectly fine, but then when i combined the drop down component into another bigger component, the drop down design is stretched when i checked the prototype.
but then if i take it out of the bigger component and try the prototype individually, it works perfectly fine. anyone knows why? and how to solve this? hopefully i explained it well enough for u guys to understand my problem. sorry if its a little confusing
here is what it’s supposed to look like. this works if I take the drop down component out of the combined component
  • 2545 replies
  • December 13, 2023
Thanks fore the post. Regarding the duplicate components, are you using nested instance? If it’s the case, the issue could be the same with this case: https://forum.figma.com/t/issue-with-instance-component/56132. I hope the comments would be helpful. To get the nested instances to resize, you can add auto layout on each variant.
I might be misunderstanding, so Please let me know if I’m missing any additional points! If you can’t solve it, could you share the file link?
