Alignment not working
  • October 26, 2023
  • 5 replies
  • 2162 views
olayinkapinmo
Hello there,
I am creating a calendar, everything else seems to work fine except my alignment doesn’t work when I put a double-digit number.
I have tried using the fix height and width but it doesn’t align the number to the middle of the circle.
Screenshot 2023-10-26 113407
Best answer by Haroll
Hi @olayinkapinmo
You should try to use a frame or an auto-layout frame to handle your problem. Frames, unlike groups, have a special feature dedicated to what you trying to achieve and its called constraints.
Frame
You need to group all your item (background, number, dot) in a single frame (select them all and press cmd+opt+G or ctrl+alt+G) once it’s down you can select your text and
  1. On the right panel, constraint section (as shown below) you can specify how you want your item to behave according to the frame size (in your case “center”)
  2. Don’t forget to center align your text also
Auto-layout Frame
While basic Frame let your align items independently of each other, an auto-layout frame will manage the alignment the same way for all items inside. Since you want the text and the dot to be align at the center, it could be a good idea to use this, as adviced by @uipastel
  1. Take the text and the dot and press shift+A to make an auto-layout.
  2. You will need to take care of the background on the auto layout. On the design panel on the right add a Fill and play with the corner-radius so it will be round
  3. Then you can play with the Auto-layout section to align everything at the center (as shown below)
let me know if it helped
uipastel
  • 30 replies
  • October 26, 2023
why the size 49x50? in not consistency in your design, you can makes 50x50, put text in shapes, now you can select your eclipse and text using shift (windows) after that click a or shift + a
olayinkapinmo
It still doesn’t work
uipastel
  • 30 replies
  • October 26, 2023
Group 4
Haroll
  • 273 replies
  • October 26, 2023
Hi @olayinkapinmo
Frame
Auto-layout Frame
olayinkapinmo
Thank you so much. it worked perfectly
