Add & Removing with Variables
  • February 8, 2024
  • 206 views
I am newbie to variables and I haven’t worked much with it and I was just wondering is it possible to create a dropdown menu with variables which can add or remove menu items from the drop down?
For instance, If I need more than 3 menu items in that drop down but I have added only 3 menu items in the main component, Is there any possibility to add or remove with variables?
Michel_Schafer
I have the same problem again and again. The only workaround is to always add as many items in the master component as I need. Because: You can always hide items within an instance. You just can’t add new ones.
There should be “expandable properties” that can be expanded within an auto layout.
