Add Eraser
  • April 22, 2021
  • 17 replies
  • 50508 views
Kalle
Hey, first off — I LOVE this feature! 🔥 💯 🔥
Secondly, Im trying FigJam out on an iPad with the pen and would really need a eraser tool to be able to quickly remove scribbles. Preferably enabled with a modifier key.
My thinking is;
  1. Have the pen selected
  2. Press modifier key (maybe alt) to activate eraser
  3. Release modifier key and go back to pen tool
Mez_Dumas
  • April 22, 2021
There’s the option to use white but this isn’t the same as having an eraser as it covers the background sketching dots.
Birgit_Stenzel
FigJam is awesome! You guys are brilliant!
The eraser could also be a seperate tool like the pen
Kalle
  • April 22, 2021
Yes! Was thinking the same! Could look something like this 👇
Valsaraj_R
I couldn’t find an eraser tool
Josh
  • Former Community Manager
  • April 22, 2021
There’s no eraser tool but you can always select your objects and delete.
This is great feedback though. How do you imagine the eraser working? Would it be to erase the marker/pencil, or would it erase shapes and stickies too?
Would love to hear more about this! 🙂
Kalle
  • April 22, 2021
I would lean towards having the eraser erase marker/pencil. Could have two modes, “object erase” and “px erase” — Like apple notes.
I’m not sure if it should erase stickies and shapes. I mean whatever I draw on a whiteboard I can erase but stickies I need to toss. But could be confusing to draw an invisible line to what the tool can remove.
Bill_Stewart_S
If you use a pen with a dedicated eraser button on the end or an eraser button where you hold it, Figjam should use that button to erase. That’s the ideal workflow.
However, Using the draw pen with a modifier key down (like Ctrl/Cmd or Shift) in order to erase would be a good backup for those who don’t have a dedicated eraser.
Also, in both cases, it should be able to erase an entire shape at a time or one substroke (or sections of pixels) at a time. Follow the established pattern in OneNote.
Widianto_Zhu
  • April 22, 2021
With one click or tap on the Eraser tool everything that’s erasable will remain visible, while everything else that’s not will be hidden/greyed out.
When we move the cursor over an erasable item, the item gets highlighted in response. We can erase things by clicking/tapping or scrubbing (erasing) over the surface. There’s an unerase/undo button as well in case of an accidental erase.
Perhaps also throw in erase history, something similar to Photoshop’s history panel? Or maybe it fits better as FigJam history, similar to Version History that we have in Figma?
Version History is one of the coolest feature that convince me to switch to Figma back in the days. It’s intuitive and easy to use:)
andrewfluck
The marker tool is great, and it works extremely well with the Apple Pencil on Figurative already, even if it is an unsupported workflow. If an eraser tool is given, I’m sure the app will be able to hook into that to support the double tap to switch tool and what not.
Ravi_Sirswa
we need eraser tool
Colin_Nickerson
Definitely need this please
Augustine_Correa
Well delete object maybe an overkill. Since this is free form drawing, we could have something in the whole drawing that may just need tinkering/minor modification eg: sometimes the lines overshoot etc, we don’t want to delete the whole line…just a part of it.
Deeptree
  • September 14, 2021
I’d love to use this in meetings and for ideation but without the ability to delete with my pen is pretty much unusable.
phat.dev
  • July 18, 2022
I must say the lack of an Eraser tool or at least a DELETE button makes it unusable with Pencil.
I do use Surface Pro, I like to draw with the keyboard detached. This is just impossible to not have Erase or Delete button anywhere (even in the context menu)…
  • July 18, 2022
The Eraser Tool was added to FigJam on December 14, 2021.
releases.figma.com
Jeremy23
  • November 3, 2022
Please please please…
Zarni
  • May 8, 2025
Figjam eraser really is sad. We need a real eraser tool like in Photoshop, Procreate or Paper app.. what a sad way to make a drawing tool without an eraser… :(
