Absolute confusion
  • December 30, 2022
  • 8 replies
  • 582 views
Parthiban_MK
Anyone please help me on this, For sort data I’m using absolute position, inside the auto layout but showing behind the card
IraX
  • 145 replies
  • December 30, 2022
Just change the layer order. I believe an absolutely positioned element will default to the bottom of the layer order, appearing above the rest in the frame, visually. If you had moved it to the top of the layer order, it will be below the rest in the frame.
Parthiban_MK
Those are all inside auto layout so i can’t move the layer
Antoine
  • 147 replies
  • January 2, 2023
If you go to the advanced layout menu you can switch the layer order to ‘first on top’
But you should technically be able to move an absolute positioned layer in your AL container
Parthiban_MK
I changed but it’s still behind the card
Antoine
  • 147 replies
  • January 2, 2023
Please share your file!
Osama_Turki
  • 47 replies
  • January 3, 2023
you can move the layer order of an absolute position layer to any order you like, it won’t affect the other layers. And if you are editing a component make sure you are editing the main component rather than an instance.
Parthiban_MK
It worked thanks
Kai_ByRoade_AzKai
Holy moly. I’d been looking for this for months and just stumbled upon your comment. Thank you!
