Swap variables in library
Show first post
Fred_Tinsel
  • Active Member
  • 113 replies
  • April 8, 2024
This one works better for me 😉
Figma
It’s a shame to depend on the kindness of external developers… for a function that should be native.
Sanny
  • 25 replies
  • April 19, 2024
Hi,
Could you provide an update on the status of this feature request?
Currently, our agency relies on the Variables Pro plugin, but we’ve found it lacks intuitiveness and requires multiple steps to accomplish tasks.
We are super happy with the recent rollout of typography tokens, but it is fueling our excitement for the implementation of this feature.
Cheers
It would be awesome if we didn’t have to rely on external plugins for this feature. It makes so much sense to include variables when swapping libraries. Are there any updates on whether Figma is even considering including this feature?
Sanny
  • 25 replies
  • May 14, 2024
Hi,
I’m reaching out to urgently request the addition of a variable swap function to the library’s existing swap functionality.
Our team has been facing significant time losses on projects due to the absence of this feature, and the frustration level is escalating. Currently, we are relying on third-party plugins for variable swapping, but unfortunately, they are malfunctioning, causing considerable inconvenience.
Moreover, the current state of Figma variables is not viable for agencies like ours. We urge you to consider implementing this feature internally so that it becomes a default aspect of the platform.
Your assistance in this matter would be immensely valuable, not only to our team but to numerous other agencies facing similar challenges.
Thank you!
Best regards,
Sanny
qurle
  • 9 replies
  • May 21, 2024
Up!
While waiting for native feature, I also made plugin called Swap Variables that can help you for now.
It swaps variable collections, replacing variables by their name. We use it to extend our design systems to multiple products. But it’s kinda hard to cover all the agile variable cases with current state of Plugin API.
There’s a hope that Figma will roll out multibrand suitable “extended collections” mentioned on Config soon.
Sanny
  • 25 replies
  • May 23, 2024
Thank you for the tip!
Is it possible to swap variables across multiple pages? Our component library file has a separate page for each component. 😅
qurle
  • 9 replies
  • May 23, 2024
Not for now, but I consider to add this feature. However, all-pages swapping will be a long flight…
UPD: Multi-page swapping is available now.
Eva_Willebrands
This feature would help our workflow a great deal. In addition, the selected modes on frames should also be swapped!
CamilaB
  • Active Member
  • 28 replies
  • July 2, 2024
I love the plugin. But Figma’s team should definintely add variables to their library swap function.
Hong_Y_N
  • July 10, 2024
HI @Bruno_Bach does it means the text used in component need to link to a default brand or do we need to set up a default text style within DS and then swap the brand when using components?
Fred_Tinsel
  • Active Member
  • 113 replies
  • September 13, 2024
Hello @Celine_Figma
Can we have some update about this…
It’s painful.
Does this trouble affect all subscription Pro? Enterprise? Organisation?
Please, I can’t believe you’re being so malicious. I’d like you to reassure me.
Adam_Gordon
  • 6 replies
  • October 14, 2024
Yes this still affects all subscription levels, we’re currently on the organisation plan and have the same issues.
It’s extremely painful part of the experience currently, we have several libraries and page templates that require our teams to go through every file to update them, and even then I worry it’s not 100% mapped as our files can be quite large and combing through those would take too much time.
We are also using the above plugin, although not ideal it’s the only way we can relink things (thank you @qurle for your time & effort).
They originally mentioned having ‘extended collections’ but apparently this was larger than anticipated and has been pushed back to god knows when. I also don’t even know if extended collections would really solve the problem or not, as there was very little details at the time of the original announcement.
Sara_Hernandez1
Same here. Library swap without variable swap does not help speeding up the process.
Rajan_Patel
  • November 18, 2024
You can streamline your workflow with Variable Pro. This plugin allows you to seamlessly transfer variables between collections, libraries, and pages. It’s a powerful tool to enhance your efficiency and flexibility.Variable pro
Maciej_Klebaniuk
It’s unbelievable to developed variables and “forgot” to create for libraries detector to swap them too.. I use variables in very huge scale, more than 10k in a few collections, modes and after all this, I still can’t swap libraries witch contains my Primitives colors in my main DS file. Also couldn't find a working plugin for it and not to mention how much money some people want for them.
Kirsten_Felbert
Please please please make swapping variables work with swapping libraries. I now have days of extra work to do because this doesn’t work.
Asher Terpstra
+1
This was a surprising omission that caused a significant of manual work on a recent project. It was not apparent that variables had not swapped out until a significant amount of issues were found later.
Freddy
  • 6 replies
  • July 11, 2025
+1
I can't stress enough how frustrating it is to rely on plugins for such a simple task. The native library swap process is completely outdated and lacks user-centered features. How are we supposed to swap variables if they're not even accessible in the swap library panel? Why can't we manually reassign missing components? And wouldn't it be great if we could directly identify and fix missing styles right from the swap library panel?
Duc_Dao
  • 5 replies
  • August 8, 2025
Our team recently had to switch to a new library and relied on a plugin to make the transition. The process was far from smooth and took forever.
