Bruno_Ponzini1
Sep 27, 2023 9:34 PM UTC
Set Default Text Properties
It would be awesome if we could set properties like font, size, alignment so everytime we start a textbox it would have all the properties already set.
This exists and works with shapes for example, but the text ends up overridden by the last textbox you edited.
Is there a way to workaround this or should it be a possible new feature?
Thanks
Ron_Frank
Oct 6, 2023 3:43 PM UTC
Yup. Same problem here. Looks like “set default” isn’t actually setting the default. It would be nice if Figma disabled it for fonts. Or maybe when a type frame is selected, have the menu change to “set default color” which seems to work?
RuudvdKlugt
Dec 19, 2023 3:03 PM UTC
It does seem to work now for font family and alignment, but still not for font color.
Aug 15, 2024 12:49 PM UTC
Same issue here. Wish this worked!
lauren_hh
Mar 21, 2025 5:40 PM UTC
Same, Set default properties not working at all for me.
Tom_Auger1
May 21, 2025 6:19 PM UTC
Same, selecting a textbox, setting the text color to a variable, then, with the textbox still selected choosing Edit > Set Default Properties. Figma then says “Default Properties Set”, but the next time I use the text tool to create a new textbox, the text defaults back to #000000.
This is very frustrating!
@Figma - any chance of a fix to this obvious bug? I’ve been seeing these reports for over a year now...
Tom_Auger2
Jan 9, 2026 3:53 PM UTC
Interestingly, it DOES work if you apply a Colour STYLE (not a colour VARIABLE). I’ve never understood why we had colour styles and colour variables anyway, but this is one (perhaps the only) reason to favour colour styles over variables.
Anyway, the way I’m using this is to create an ugly, default text colour to remind me to change the text to my default text variable color whenever I create a new textbox. Still a total pain, but at least I’m less likely to forget that way.
Antero
Jan 15, 2026 7:06 PM UTC
We are talking about the same thing, right? Just happened to me, so annoying and for no apparent reason
Antero
Jan 15, 2026 7:09 PM UTC
Or in my case it is the opposite? Every new text frame I try to write is in black, but I want it in white and no matter what I do it stays in black
