Jerimy_Brown1
Jan 4, 2023 6:34 PM UTC
[LAUNCHED] Paragraph spacing settings break when mixing styles in single text block
Paragraph spacing breaks if you mix text styles in a single text block.
Ideally this would function in such a way as to take on the paragraph spacing per style instead of assuming everything in a given text block wants to use the same paragraph spacing.
If the paragraph spacing was inherited by selected items, the same way the rest of the text style is, it would make quick single text block styling possible…
Right now you have to create individual text blocks every time the style changes and then merge them with an autolayout, then if you want different spacing you end up with a bunch of embedded autolayouts, which works, but it’s messy.
Przemyslaw_Cioch
Jan 5, 2023 2:46 PM UTC
Fully Agre. It took me a while to understand what’s going on there. It should work like in any other tool.
Penina
Jan 10, 2023 12:10 AM UTC
I was so sure I was doing something wrong (“this couldn’t possibly be Figma!”) and thought it would involve a quick search in the community. Now I just hope this is not too far down the roadmap/fixit list…?
Jeff.Miller
Jan 13, 2023 3:04 PM UTC
10,000,000%. Figma is fundamentally broken in this respect.
Dominic
Jan 24, 2023 5:59 PM UTC
Definitely a major issue. I’ve tested it to exhaustion and when using text styles paragraph spacing simply doesn’t work!
Milovan
Jan 26, 2023 5:45 PM UTC
I still have same problem with paragraph spacing…still nothing?
Janessa_Hayven
Feb 6, 2023 7:46 PM UTC
Paragraph spacing never works! Can someone please help??
Shevchenkoserj
Feb 15, 2023 11:44 AM UTC
have the same problem
Shevchenkoserj
Feb 15, 2023 11:52 AM UTC
ive found the thing i need in list spacing
AddWeb_Solution
Feb 22, 2023 6:13 AM UTC
Hello,
You can adjust the top and bottom margins of the text box by using the “Paragraph Spacing” controls in the properties panel.
Mar 25, 2023 8:59 PM UTC
No you can’t. It doesn’t work. That’s our point.
