pinquitte
Feb 5, 2021 10:07 AM UTC
LAUNCHED: Horizontal scroll the layers panel
What do you think about having a horizontal scroll on the layers panel? I can’t see the name of the layers and usually widen the panel to be able to see, but since I use a 13", this makes the canvas smaller.
Chad_Hansen
Oct 26, 2022 3:49 PM UTC
Would love to horizontally scroll within the layers panel. I often have to resize the layers panel to see things that are very deeply nested, but even after you get so many layers deep, the layers panel is expanded to as wide as it can possibly go and I still can’t see my layers to lock or hide. A horizontal scroll within this section would fix this!
Scott_Brown1
Oct 27, 2022 5:02 PM UTC
Would be great to either have the ability to horizontal scroll the layers panel, or be able to stretch the panel further in order to see the layer names and visibility options.
Please!! 🥰 🙏
CleanShot 2022-10-27 at 09.59.07
Scott_Brown1
Oct 27, 2022 5:30 PM UTC
Awesome, thank you!
Willow_Shelley
Nov 7, 2022 3:35 PM UTC
1,000% needed! Especially when working on a small screen the left panel can take up half my screen! Figma team, if you need a perfect use case of this working, check out Visual Studio Code, they do it very well.
Jun_Rey_Ellezo1
Nov 10, 2022 1:34 PM UTC
+1 - Is this feature request being ignored? What is the purpose of this voting then?
Nils_Nowacki
Nov 14, 2022 2:27 PM UTC
+1 / The panel and also the dialog size is way too small. Changing the size would be a key improvement for building and using design systems.
Anna148
Nov 18, 2022 2:08 PM UTC
+1 - please add this feature
Hazel
Nov 25, 2022 3:25 PM UTC
aolko
Nov 28, 2022 6:32 AM UTC
apparently tags are much more important than this
Gomes_Ivan
Nov 29, 2022 9:19 PM UTC
I have a solution for some workflows for both desktop and web. Namely, this is a decent solution for workflows that open a Figma file and do not reload the page often (I open the page once and leave it open for days, so it works for me). It’s not ideal for workflows that reload the page often because you have to do about 15 seconds of work to enable scrolling, which would be annoying if you had to do it multiple times a day. Script and step-by-step instructions below.
This script will inject styles into the page that will make the layers panel scrollable, and the indentation of children smaller, too. I vouch for this code’s safety, but be smart and read the code yourself. It’s not complicated. And you’re free to tweak to your preference.
const s = document.createElement('style');
s.innerHTML = `
[data-testid="layer-row-with-children"],
[data-testid="layer-row"],
[class|='scroll_container--innerScrollContainer']:not([class|='object_row--instance--']) {
    /* Make each row take up as much horizontal space as it can. */
    width: 100% !important;
[class|=pages_panel--objectPanelContent-] {
    /* this is what enables scrolling (if needed) in both directions */
    overflow: auto;
[class*=js-fullscreen-wheel-event-capture][class*=objects_panel--scrollContainer][class*=objects_panel--scrollContainerWithBorder][class*=scroll_container--clipContainer] {
    /* This overrides the inline styles that get added on sidebar resizing. */
    width: 1000px !important;
    position: relative;
[class|=object_row--indent-]:not([class|=object_row--indent-]:first-of-type) {
    /* This reduces the indentation of nested layers */
    width: 5px;
document.head.appendChild(s);
// Additionally, fix the Layers panel label. Prevent overlaying the main area in certain edge cases
const header = document.querySelector("[class|=pages_panel--objectPanelContent-] [style*='translate3d(0px, 0px, 0px)']");
header.style.position = 'absolute';
header.style.transform = 'translate3d(0px, 0px, 0px);';
You can save this script as a Chrome Snippet for (relatively) easy reuse by first opening the Developer Tools (top-right dropdown => Help => Troubleshooting => Toggle Developer Tools), then navigating to the Source panel’s Snippet tool and creating a new snippet with the contents of the script. Click the button to run the snippet whenever you load/reload your Figma tab, then you’re free to close the dev tools.
It’s not cosmetically ideal, but it is more functional and enables scrolling! Notable limitations:
  • The “1000px” width is hardcoded, and there’s no way to avoid it without extensive modifications that I don’t have time for. This probably creates more horizontal scrolling area than you actually need.
  • The top-level entry is supposed to be a static section header visible at all times, but this code makes it only visible when scrolled to the very top. Nobody cares about a static header that does nothing, so I didn’t bother to search for a fix.
(Final notes for developers: the Figma code is horrendous. Instead of letting the browser’s own layout engine place elements, they make everything absolutely positioned and use css transforms to translate the rows up and down. I can’t imagine the nightmare it must be to maintain this.)
