fernandolins_cs
Mar 12, 2024 5:47 PM UTC
Find and Replace Variables
One of my clients is going through a rebranding process. I need to reroute many color variables at once, replacing a group of color variables with another one. There is no easy way to do it, and none of the plug-ins that allow swapping variables will swap variable groups, only collections. I have to go into the Variables panel and change one by one, manually.
If Figma had an intelligent find and replace system for variables, where I could, for example, replace all color/component/primary tokens with color/component/secondary tokens in batch, that would make my life a lot easier.
It would be especially great if it worked similar to text find and replace, where I could define if the variable name contains or does not contain, matches or does not match a string or a collection name or a group name, and similar kind of rules that allow for advanced manipulation, that would be amazing.
Pavel_Kiselev
Power Member
Mar 12, 2024 10:33 PM UTC
Out of curiosity, what is a variables group? Haven’t heard before
fernandolins_cs
Mar 14, 2024 6:22 PM UTC
Mar 27, 2024 3:54 PM UTC
I haven’t found a more convenient way to do it myself yet, but there is a plugin available “Swap to Local Color Variables”
Jul 19, 2024 6:54 PM UTC
I need this SO bad as i’m building out a design system
Jul 19, 2024 7:06 PM UTC
These tips are only for the variables panel, we need the find and replace for the component itself. I duplicated a single select dropdown component with like 50 variables (color, border radius, space etc.) to make a multi select component and now need to replace each variable one by one from component/single select/___ to component/multi select/___
Jul 19, 2024 11:52 PM UTC
Hey All, thanks for the feedback!
We’ll pass this onto the team for future consideration.
Max_Schulmeister
Sep 12, 2024 9:58 AM UTC
I wrote a plugin, that does exactly that.
Give it a try.
https://www.figma.com/community/plugin/1415619314028200863/find-replace-variables
