Natalie_Zdan
Jul 20, 2021 5:29 PM UTC
FigJam Presentation Mode
Reopening a thread for interest in a presentation mode in FigJam (here’s the original thread that’s now closed).
Of course someone can follow a specific user as they zoom and scroll through a board, but the viewer experience–especially for those unfamiliar with FigJam–could be improved if a specific presentation mode existed. Thinking similar to Miro’s, which would mean also needed to add “frame” elements to be able to have it function like a slide deck.
Martijn_Hoppenbrouwer
Mar 29, 2023 11:08 AM UTC
Yes please - miss this so much!
Jessica_Wright
Apr 4, 2023 4:39 PM UTC
Do you know if anyone figured out a workaround? I was thinking of embedding a figjam section or something into a Figma file. I’ll try “the FlyOver plugin” mentioned. But, I’d LOVE this feature!
My use case: get my trio all in one spot (one source of truth) and present nicely to stakeholders WITHOUT PowerPoint.
Apr 4, 2023 4:50 PM UTC
Thank you all for your feedback!
We expected FigJam to be used primarily as an online whiteboard for meetings, brainstorms, diagrams, research, etc. But we’re so happy to hear it’s potential is reaching past our initial imagination.
We love hearing that you want to be able to present from FigJam, and we’ll pass this idea along to our FigJam team for future consideration!
Pete11
May 4, 2023 5:19 PM UTC
I just tested the Tour Guide plugin. This is great for getting some of the Miro presentation mode features mentioned here, in figjam.
I found that using a frame in 16:9 proportions with screen designs overflowing worked well for both navigating a presentation (zoomed in) and panning around the board (zoomed in / out) and going back and forth between the two with arrow keys or the Tour Guide UI. In this case some objects can fit a wide screen frame while others don’t, such as presenting upfront content and then screen designs in from the same figjam.
(I did not test Flyover because it has limits on the free version.)
Jeremy_Jodeau
May 31, 2023 2:15 PM UTC
Hi @dvaliao,
We really need this features.
Figjam is used to braimstorm, research…but at a certain point, you need to present the result.
Miro presentation mode is great for that!
Jun 27, 2023 3:58 PM UTC
I would love a presentation mode in Figjam. I’ve tried using Miro but since they don’t allow custom fonts using Miro to present to clients often is a no-go (I know there’s google slides but I’m not a huge fan).
I really would love to try and move myself (I’m a strategist) and my teams out of keynote (or ppt) and use tools like Figjam to present (I’ve used Figma Design but it’s much more laborious).
Please?
Sara_Camnasio
Jul 5, 2023 8:18 PM UTC
Please yes - so needed! I often get the feedback while presenting in Figma that people are “dizzy” from zooming in/out and trying to get the right objects in frame. It’s badly needed. Miro had a nice feature like that where it smoothly transitioned between frames. What didn’t work about the Miro feature was that you couldn’t easily figure out what order it was choosing to show the frames in.
Would be great to have a way to customize the order and size of areas that you could transition between smoothly.
Jul 15, 2023 3:54 PM UTC
Yes, same, I was evaluating Mural, and they have this presentation mode and additional fancy navigation capabilities between different sections or simply different areas of the canvas. So, you can create a nice storyline or simply a menu for navigating around the canvas without losing yourself
Olivia_Pasquinelli
Sep 18, 2023 3:55 PM UTC
Let’s bring this one back - would REALLY like this feature
Aleksandrs_Mjasojedovs
Dec 14, 2023 8:47 AM UTC
The workaround I use:
  1. create Sections to fit the screen ratio/size
  2. add content into sections
  3. lock sections
  4. hide ui
  5. Select first frame and Zoom to Selection (SHIFT+2)
  6. use Tab to switch from one section to another while presenting.
