Ryan_Leichty
Oct 23, 2023 4:09 PM UTC
CSS Outline and Outline Offset
Figma should add an outline and outline offset property similar to the properties in CSS. This is useful for focus styles among other things.
Currently, there are a number of approaches that you can take to achieve a similar effect, but neither is ideal:
  1. Drop shadow: one problem with using drop shadows to create a focus outline is that you have to have a fill.
  2. Absolutely positioned frame: you can add an extra frame within an element that’s absolutely positioned and apply a stroke. This isn’t ideal because you’re required to add an extra, unnecessary frame to every element that you want to add an outline to.
ksn
Oct 24, 2023 3:54 PM UTC
Thanks for the feedback @Ryan_Leichty – I’m adding some additional tags to your suggestion to surface it a bit better for others who are looking for something similar 😁
Brian_Heston
Nov 29, 2023 5:05 AM UTC
This has been an issue for a while and I’m now running into an issue with my previous workaround which was option 2 above.
The biggest thing that Figma needs to understand is your customers are designing UI and a lot of that UI is going to use web tech. The abstraction to make it more of a “drawing” program causes issues all over the place like this, or for another example with different colors on each border side. Please at least allow us to do common things we can do in css.
Matthew_Ryan
Nov 6, 2024 9:14 PM UTC
Seconding this. Right now you need to add an additional frame, but that can cause things to be wonky because an outer frame influences the component’s size and position. In CSS an outline gets painted on top of things rather than influencing the position of any element.
Pavel_Kiselev
Power Member
Nov 6, 2024 9:38 PM UTC
Nah, mate, autolayout and absolute positioning to the rescue. You get exactly what you describe. Outline won’t affect element size and position as you paint it on top of everything else.
My biggest issue were radii and design tokens. There is a simple math but it is still there. Anyway, I ended up with simple Boolean exclusion and it works fairly well!
Pavel_Kiselev
Power Member
Nov 8, 2024 12:10 AM UTC
jamiefang
Nov 8, 2024 5:28 AM UTC
Designer may use inner box shadow to create a focus state for text field. Outline property cannot achieve the same effect.
On one hand, I agree that using absolutely positioned frame for focus style is a chore.
On the other hand, I think outline property need to evolve itself. What designers and developers need is a ‘focus state’ / ‘focus ring’ property. Outline property is not adequate.
Pavel_Kiselev
Power Member
Nov 8, 2024 6:58 AM UTC
Inner shadow? Mind elaborating? 😉
Box shadow does not let you have an offset, just a steady outer ring.
And what is “focus ring” in real world though?
jamiefang
Nov 8, 2024 7:13 AM UTC
wise.design
https://main--641de2ace0e1566a6a450fad.chromatic.com/?path=/story/visual-tests-layouts--form
In Figma, designers may use inside stroke to create this effect. But developers usually use box-shadow to avoid layout change. (If box-sizing = border-box, increasing border width will affect layout.)
I borrow the term ‘focus ring’ from Wise. It means a line around the focused item to indicate which item has keyboard focus.
Pavel_Kiselev
Power Member
Nov 8, 2024 7:43 AM UTC
In the web, a focus ring is either a box shadow or an outline or another element, positioned in a certain way. These are all of the options.
A real CSS outline can have a negative offset and it will appear inside the element.
With a few layers, you can make something that is like a real CSS outline
And I use only one radii value, which is important, especially if you on the system and use tokens for that.
My personal preference is to make the focus ring outside of an element. It makes it much easier to spot since the element gets visually bigger. I prefer external component since I can apply whatever colour I want without creating unnecessary box shadow effects for each combination I want.
Aretha Alves
May 12, 2025 12:41 PM UTC
I reaally want this on Figma, speacially now that I’m working a lot with design system and design tokens!
