OG_Can
Nov 22, 2023 5:17 PM UTC
Batch Text Style swap similar to how color styles work
Make text style changes the same way color styles work: being able to select all frames and swap styles from the right column that applies to every instance.
Situation: If you need to swap the font styles used in a project in bulk; you need to edit the style definition but you cannot swap a style with another one the same way you can do with colors.
Example: You have a white label product where you need to swap a style with another from the design system. For colors, you can CTRL+A and select every frame, and change the colors you want from the right column controls with a few clicks.
For text styles, you have to go to each element using that style, and change it one by one.
I see that this was flagged more than a year ago but did not have any discussion over it - community input welcome as I cannot find a way around this yet.
Nov 23, 2023 7:48 AM UTC
Hi there,
Thank you for providing feedback! I will share this with our internal team. Your input is highly valued, and we will take it into consideration for future enhancements.
Toku
