Tin_Le2
Oct 21, 2024 7:37 PM UTC
Add all control configuration shortcuts to the Command + K shortcut.
I love the new Command K shortcut. It would be awesome to have the ability to search or use shortcuts for everything.
If you’ve used Rhino 3D, you know you can type a function, and it shows up for adjustment. Having something similar in Figma’s Command K shortcut would be amazing. For example, if I select text and type “truncate text,” the option should appear when I search with Command K. Then, I just press enter, and the function toggles based on my current state, opening the panel for more options if needed. You’ve already done it with Auto Layout fill/hug, so having it for everything else would be very useful.
