Lucas_Orellanos
A shortcut to open the "Local variables" window
  • July 10, 2023
  • 15 replies
  • 3648 views
Hello everyone!
I think having a shortcut to open/close the local variables would be very helpful.
For example in cases where I’m prototyping and need to access the local variables to ensure the accuracy of the variable names or values that I’m assigning in the interactions.
Currently, if I want to do this, I have to switch between the prototype panel to the design panel in order to open the local variables, check them and then go back to prototype.
Note:
I am aware that it is possible to keep the local variables window open, but this often leads to numerous bugs in the prototype. For example, when it is open, I am unable to drag the prototype interactions to reorder them.
Koekie
September 15, 2023
Excellent idea! I also find it very annoying that if you want to publish updates the window automatically closes and you need to reopen it again afterwards…
Coti_Rassi
December 14, 2023
Excellent idea, Lucas! I think it would be a shortcut that would help us a lot when prototyping. It’s true what you say about leaving the variables window open causing many bugs in the prototype. I really hope they can make an improvement on this
kmh
This is a great idea. I’m trying to debug something right now, and I keep having to switch between panels.
Ayan_Mishra
Its a must have!!
Agni_Kaster
+1
Even in Design Mode it is cumbersome to access the Variables Panel. You need to first click off the canvas, just to show the ‘hidden panel’ with the local styles, then click on Local Variables, then click on the Variables window, then navigate to whatever var you are looking for, then re-select the frame you had selected to apply a var in the first place. And then, the Variables window auto-closes because you forgot that if you don’t reposition it a bit, it will not stay open, so then you need to go thru the cycle again.
So the wishlist is:
1. direct access to Variables Panel from the main figma ui
2. make it stay open
Vadim_Vaitenko
The workarounds are to have a big enough monitor or using quick action (perhaps keep that `Toggle variables` in your clipboard manager 🙄). I wish at least it would be available in the menubar menu, so I could bind something using OS tools or it would’ve been available through the API available for plugins, but no dice.
jjcm
Not a bad idea at all. We’re currently doing some updates here. Do you have a preference for what the hotkey is?
Wesley Eland
Shift+Option+Command+V would be nice 😁
Mathieu_Moussa
​@jjcm not sure about what the key is, maybe something with option+ L or V involved.
Since you’re here, and you folks are working on some updates for it, i have a few more suggestions:
  1. Since “Local Variables” is slowly taking over “Local Styles” (based on what i see), can we expose the variables (or a summary) in the side panel directly, and then open the window to see more if needed?
  2. Can Figma introduce a way to mark a Design file as a “Design System” in which variables could have a dedicated panel next to “Design” and “Prototype”
  3. If a file is marked as “Design System”, maybe we can have a button to access local variables from bottom bar (next to plugins for example), that will make it omni-present. This way, even i have items selected, i don’t have to unselect everything to access local variables, i can directly open it from the bottom bar. (this might be a good idea for all design files).
  4. If i’m in the Local Variables panel and select a specific page/variable, the panel doesn’t retain my selection when i close and reopen it. Instead it takes me back to the first page every time.
  5. Finally, consider a shortcut button for “Publish” directly from Local Variables, since designers usually want to change a variable in the system and want to see it reflect on other files.
Thanks!
DanielY
Agreed, this is currently one of my biggest pain points. Overall the local variables panel is quite a pain to deal with, I’m always having to move it in the way, move out of the way, reopen it etc.
It’s a very powerful feature though and I’m using it more and more. Would love to see the UX improved here.
