Jul 20, 2023 12:34 AM UTC
Widget API does not reflect the change of Text width from fixed value to "hug-content" on the layer
- 0 replies
- 360 views
I am trying to add a function to a widget I am currently developing that changes the width of text with the touch of a button.
I have implemented this so that the width of the text is held in a variable using useSyncedState and can be switched between a fixed value and “hug-content”.
If width is a fixed value, it works as expected, but when switching from a fixed value to “hug-content”, it is not reflected in the width of the Text layer.
Here is the sample code.
const { widget } = figma
const { useSyncedState, AutoLayout, Text} = widget
function Widget() {
const [textWidth, setTextWidth] = useSyncedState<WidgetJSX.AutolayoutSize>('textWidth', 'hug-contents')
return (
<AutoLayout
direction="vertical"
<Text
fill={"#cc0000"}
onClick={() => {
if(textWidth === 'hug-contents'){
setTextWidth(300)
}else{
setTextWidth('hug-contents')
{'textWidth = ' + textWidth}
</Text>
<Text width={textWidth}>
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod
</Text>
</AutoLayout>
widget.register(Widget)
The following is the result.
You can see that the value of the textWidth variable is not reflected as expected.
Is this a bug in the WidgetAPI?
