Jan 25, 2024 9:53 AM UTC
Variable panel : bug when reorganizing section
When I try to reorganize different section in the variable panel it is alway buggy :
  • Groups ungroup.
  • Group are integrated into other groups instead of between groups.
  • Groupss disapear
  • Cmd+Z go back to multiples actions instead of just one.
    Jan 26, 2024 1:53 AM UTC
    Hi @Benjamin_bpifrance , Thanks for flagging this! I tested on my side but it seems to be working normally.
    Would you mind sharing a quick video recording of the issue you encounter? And a copy of your file, if you are able to.
    This will help us to better visualize the issue and see if we’re able to reproduce the same behavior.
    Thank you for your help here! I look forward to hearing from you soon.
    Jan 30, 2024 8:59 AM UTC
    Here is a video showing the problem Variable-panel.mov - Google Drive
    Feb 6, 2024 7:53 AM UTC
    Hello again @Benjamin_bpifrance! First and foremost, thank you so much for waiting.
    We truly appreciate you sharing this video! I’ve forwarded this valuable information to our engineering team to enhance the UI.
    Thank you so much for your help in reporting this issue!
    Let us know if you have any follow up questions!
    Feb 6, 2024 8:36 AM UTC
    Thanks @Junko3
