Crystal_Peach
Nov 28, 2024 1:25 PM UTC
Text is highlighted by browser incorrectly when changing property sort order using drag and drop (within the create component property dialog)
This bug can be reproduced as follows:
  1. On a component with nested components, create a new instance swap property.
  2. Add multiple preferred values. 4 or more will demonstrate the issue more clearly.
  3. Use drag-and-drop to drag a preferred value up or down. While dragging, the UI highlights the text of any of the “in between” items.
In the following screenshot, I took the first item and dropped it into the third position. This is the result:
Note, this does not happen on the main component’s “edit instance swap” dialog, only when initially creating the property in the “Create component property” dialog.
