Scrolling in prototype view glitching bad
  • May 30, 2025
  • 12 views
Nate50
I have a few prototypes I’m working on, and whenever I scroll in the prototype presentation view, it will jump either up or down and totally glitch in terms of the scroll amount. I’ve tried all sorts of things like wrapping any components in Frames, removing any fixed position elements, and simplifying it as mush as possible — it’s still happening.
Is this a known Figma bug that others are encountering? Thanks!
  • 2545 replies
  • June 3, 2025
Hi ​@Nate50
Thanks for reaching out. It sounds strange. Do you use a browser app for the presentation view? If so, an extension could cause this type of problem, so can you please try disabling your browser extensions one by one and then check after each to see which one might be causing the issue.
Could you try the troubleshooting below?
  • Close any Figma tabs you're not using
  • Browser: Force-quit and open Figma in a new browser window.
  • Desktop App: Force-quit the Figma Desktop app and restart it. If the issue persists, try clearing the cache.
If the issue persists, could you share the prototype and file links with access to support-share@figma.com? It won't affect your billing. I hope I can investigate it further!
Toku
