Publishing failed: Please reload the page to publish
David_Brien_Swann
Getting the “Publishing failed: Please reload the page to publish” error when I try to publish.
I’ve gone through the older treads but haven’t found a solutions beside Figma sent out a fix. I’ve tried everything I can think of including the obvious solutions like reloading tab and restarting computer.
I’ve tried deleting all new components and even restored earlier versions, from the version history panel, that were previously published. Yet still no luck. My other libraries will publish, but my main library will not. 🙄
nini_dai
  • May 30, 2025
I’m experiencing the same issue, tried different things but no luck.
Nathan7
  • May 30, 2025
Our company is facing the same issue. :-(
cloudyrobin
I have a component library that I has previously been published. I am trying to publish it again with more changes, but after clicking the publish button it says "Publishing failed. Please reload the page to publish".
I have tried reloading, I have tried rolling back to a version that was successfully published, I have tried publishing from the web client instead of the app, I have tried publishing one component at a time, and even tried to unpublish the library, which also didn't work.
Anyone ever had this happen before? I'm tearing my hair out.
Chrystal Ho
I’m also facing the same issue.
petebarr
  • May 30, 2025
Same here. It’s only happening to 1 library that’s quite big strangely. I reverted back to when the library was previously publishing and even back to when the file was first created but still getting the failure error.
  • Figmate
  • 2250 replies
  • May 30, 2025
Hi there, Thanks for reporting this!
This might be related to an ongoing bug that our team is already aware of. Once we have more details on this, we'll be sure to update.
We really appreciate your patience as we work on this.
alex_duong
  • May 30, 2025
I have a problem with figma file when publishing my library. I have closed and reopened the file and figma many times but still have this problem. It affects the progress of my project. Please fix it quickly.
alex_duong
  • May 30, 2025
Me too. I can't be calm right now. 🙄
Gayani_S
  • 2210 replies
  • May 30, 2025
Hey everyone, thank you for your patience while the team was investigating this issue!
Our engineering team have deployed a fix for this issue now, can you please refresh the browser/restart the Figma app, and check if publishing is working for you now?
Apologies for any disruption that was caused by this - please do let us know if you experience any issues when trying to publish now.
David_Brien_Swann
Tried updating this morning was able to successfully publish. Hopefully this issue is resolved. Anyone else able to successfully publish?
Kevin Tang
  • May 30, 2025
I am still having this issue.. reached out to Figma support.. but no news yet.
Kevin Tang
  • May 31, 2025
Has anyone got any updates on this? I am still unable to update/publish. Is it working for you?
Tom Reem
  • Figmate
  • 280 replies
  • May 31, 2025
Thanks for checking in here, ​@Kevin Tang — and sorry to hear you're running into trouble.
From what I can see, the issue you're encountering may be related to a separate one that the team is currently investigating. Our Technical Quality team is looking into your report and will follow up via the email address linked to your account.
Appreciate your patience — keep an eye out for updates there!
petebarr
  • June 2, 2025
I’m able to publish now ​@Gayani_S. Thanks!
Ammar_S_Mitoori
Having the same issue ! I thought it was only me !
