Leter
Apr 3, 2025 5:50 AM UTC
"Pasted with unpublished variables" despiste source library being 100% published & updated
I’m working on a project with 2 files:
  • the Design system, containing the entire component, style and variable library
  • the Delivery file, containing the final mockups.
I draft mockups from a “Sandbox” page on the Design system as a way to save time by limiting library publications & updates. Then once it’s ready, I copy/paste the final mockups from the Design system file to the Delivery file.
Until now I had no issue. But today, I’m getting the following message:
I don’t understand why I’m getting this message. Obviously I want to keep all variables attached only to the Design system file as the single source of assets.
I’ve double-checked: the library in the Design system file was fully published and updated on the Delivery file before I copy/pasted the mockups into the latter file. I’ve done it multiple times.
The Design system file contains a few hundred variables, and if I do click “Copy variables into this file” on the banner, the confirmation message says “21 variables pasted”.
I’m getting confused with this and am concerned that my Design system libraries are getting out of sync with the Delivery files it’s supposed to feed.
Alexandra_Moura_DSG_1
Apr 14, 2025 5:01 PM UTC
Did you manage to solve the issue? I’m getting the same problem
MJibril
Apr 20, 2025 11:46 AM UTC
I’m experiencing the same issue. Clicking the “Copy variables into this file” button creates a few local variables in the design file that already exist in my design library and have already been published.
ksn
May 1, 2025 6:07 PM UTC
Hey all - I’d like to help all of you get this reviewed and solved.
In instances like these, it’s hard for me to tell immediately what the issue is. Libraries are unique to each person using Figma, and what may be happening could be different for each of you.
I think it best to have our support team look into this. Would you all be able to do the following?
File a ticket here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Share edit access to the file[s] that your variables keep triggering this message on with support-share@figma.com, if you can do so. This is the official support file sharing email, and you won’t be charged for doing so. No worries if you can't share - we can still help
Include the name of the file you’ve shared within the form you fill out (this helps us locate the file easily).
Once you’ve done that, let me know. I’ll get your tickets escalated 😁
jaqueventurim - k2
Jul 29, 2025 5:01 PM UTC
Hey ​@ksn I did sent the email
Adam34
Sep 9, 2025 11:14 AM UTC
It might be a logotype that you’ve added to the library or anything else with different colors that you copy with other components. Check copied components and track the cause of the problem.
philbert
Oct 28, 2025 9:21 AM UTC
Same issue here! Strange because we did not use any variables. Anyone figured the source? In our case it resizes Icons & unalignes nested components.
philbert
Nov 7, 2025 10:38 AM UTC
Problem solved! If someone has the same issue:
For us it helped to select the instance and to select regenerate all instances from the action tab. Hope the bug will be fixed in the future.
Ruth Tsang
Mar 17, 2026 11:14 AM UTC
Yes super annoying bug. When I updated the component, it changes back to the old version (which doesn’t even exist in my library anymore.
