Overrided color of nested component deleted/reseted when switching variant with variables ?
  • February 7, 2025
  • 4 replies
  • 91 views
David60
Hi,
the color of my nested component was reset when I using variable to change this component variant.
My component :
I override the color​​ in the instance and change manualy the variant  → Overrided color was keeped
I used attach the variant name to my variables → Overrided color was keeped
I nested Component 1 to a second Component 2. Changed manually the variant →  Overrided color was keeped
I used variable to automaticely change variant → Overrided color reseted !
There are a soluion to keep the overried colors ?
treasure
  • February 7, 2025
+1 to also having this issue, our team expert is also stumped since sometimes it works but when we nest another component instance the variable we set also resets the properties
  • 2545 replies
  • February 13, 2025
Hi ​@David60 ​@treasure ,
Thanks for reaching out. I hope I can check the setting, so would you be able to share the file link with access to support-share@figma.com? It won't affect your billing. I hope I can investigate it further.
Toku
David60
  • February 13, 2025
Toku
Thx, I send you all informations in a PM
David60
  • February 24, 2025
Hi ​@y_toku have you investigated and reproduce the bug ?
