Figma Devmode MCP doesn't work
welsewool
I tried Figma MCP when it was presented - and everything worked perfectly, but previous week it stopped responding for most of my models, but for some it randomly gives something. Actually it doesn’t work for me as it worked previously.
Does anyone knows what’s the issue and how to resolve?
Yarden K
  • Figmate
  • 10 replies
  • July 7, 2025
Hi ​@welsewool, thanks for reaching out!
Could you share what error you’re seeing when it fails? even a quick screenshot or the error description can help us understand what might be going wrong.
In general, there are a few common reasons the MCP might not behave as expected.. here are some quick things to check:
  1. Selection size - does the issue happen with all selection sizes? Can you try calling the MCP on a smaller selection and see if it behaves the same?
  2. Figma <> IDE connection - can you make sure the MCP is still enabled in the Figma file you're working in, and that the tools are loading properly in your IDE?
  3. Refresh both environments - Try refreshing Figma and restarting your IDE. That often helps resolve temporary sync issues.
  4. Update Figma - Make sure you're running the latest version of the Figma desktop app.
Let us know if any of these helped, we’d be happy to help troubleshoot further!
welsewool
  • July 8, 2025
Hi ​@Yarden K
I am trying to reach Figma via Cursor (which worked week ago) and currently I just receive that it’s a connection problem.
I have tried all you mentioned - turning on / off, reinstalling, updating, different files, different sizes… Still no conversation between Cursor and Figma (but MCP is connected to it).
I also tried in other IDEs and same issue.
Fabrício Sautner
same problema with VS Code!
Same here I’m seeing
{"jsonrpc":"2.0","error":{"code":-32001,"message":"Invalid sessionId"},"id":null}
Kash Badami
  • August 12, 2025
Same problem. Claude code simply cant connect to Figma MCP. Figma, you are now a public company with billions in raised capital. Would you please fix your mcp server. this is such a pain.
Takasur A.
  • August 12, 2025
Same problem, the SSE endpoint works, I don’t know where that is installed. I tried uninstalling Figma and install the latest and still the same issue.
