Don't copy link in text with variable in paragraph spacing when copy instance
  • April 23, 2025
  • 13 views
Ravil Shafikov
If there is a text inside the Component that uses a Variable for the Paragraph Spacing, then when the link is set to the text in the Instance and the Instance is copied later, the link off the text.
  • Figmate
  • 2165 replies
  • April 24, 2025
Hi ​@Ravil Shafikov, thanks for reporting this!
Thanks for the screenshot and video – that was really helpful. I tried it out and can see the issue you're running into.
I also observed that if the variable isn't attached to the paragraph spacing in the main component, the linked text works correctly on the copied instances.
I totally get how much better it would be if those text links stayed put when you copy an instance.
I'll go ahead and create a report for our team to investigate. While we can't provide a timeline for a fix, we sincerely appreciate you bringing this issue to our attention.
Thank you again for reaching out to us!
