Davide9
Dec 20, 2023 2:40 PM UTC
Component publishing loop after moving component
Hi!
Something very unusual happened today:
I moved some master components from a file to another, as I have done may times before [cut > paste > publish].
I immediately notice that some of the pasted components were flagged as “invalid” and decided to history revert the changes, after that the trouble begun.
Once the components were reverted in the original file, they asked to be published again. After doing that all the instances of those components (both in the same and other files) lost the connection to the master components and asked to “restore component”.
When I try to restore the component, the restored master asks to be updated, only to cause the instance to lose the connection again and ask a new “restore component”. An infinite component publishing loop.
Furthermore, no matter how far I go in the history, this problem persists and I can’t seem to get rid of it.
Any ideas on what could have happened?
Thank you very much in advance!
Gayani_S
Dec 21, 2023 7:42 AM UTC
Hey Davide, would you mind if I create a support ticket on your behalf I guess the best solution is here if support takes a look at your file to help you out?
Davide9
Davide9Author
Dec 21, 2023 9:21 AM UTC
Please do! And thanks for reaching out! 😃
Davide9
Davide9Author
Dec 21, 2023 9:37 AM UTC
@Nat14 Follow the thread update
Davide9
Davide9Author
Dec 21, 2023 9:38 AM UTC
Thank you so much, send the link when you are done so that I can provide more links / information.
Dec 22, 2023 1:29 AM UTC
Hi @Davide9 - Although Gayani mentioned we’d create a ticket instead, could you please submit one using this form: https://help.figma.com/hc/en-us/requests/new? Our support team will be able to identify your account details if you file the ticket using your Figma account email.
Apologies for any mix-up, but we’re hopeful our support team can delve deeper into this issue!
Thanks for your understanding!
Toku
Davide9
Davide9Author
Dec 25, 2023 9:56 AM UTC
Hello everyone,
after some helpful communication with the support and some hours sank in troubleshooting components here is the solution that I found:
  1. The “looping” components are doomed, no use trying to fix them.
  2. Restore the previous file history version of BOTH files (the one you cut the components FROM and the one you pasted them INTO) to right after you moved the components the first time.
  3. Now do the reverse: move the components from their current location back to file where they were originally located following this process.
  4. Check that all the components have kept their properties especially when they contain sub-components, as it can happen that they can detach.
  5. Move the components again to the file file they were meant to be moved in following the same process.
  6. Check again that all the components and their properties are intact and you should be done!
Takes a little time, but it works! At least it worked for me
Many thanks to the support team that kept the communication even during the holiday time!
Dec 28, 2023 11:48 PM UTC
@Davide9 thanks so much for sharing the details! So helpful. Glad you’ve solved!
Andrew_Kuhar1
May 22, 2024 2:57 AM UTC
I’m stuck w/ this exact same “Restore Component” loop problem with a handful of core components. I understand most of what you described here, except for Step 2. Could you provide more details as to how you navigated this step, specifically the “Restore the previous file history version?”
Davide9
Davide9Author
Aug 1, 2024 7:45 AM UTC
By that I mean revert the whole file to the version timestamped right after you moved the components the first time.
