"Change to" is not working
Apoorva Gaur
Hello Figma Support,
I am currently facing an issue with the "Change to" interaction feature. Despite setting up my interactive components properly, the "Change to" action is not triggering the expected state or swap.
  • Figmate
  • 2118 replies
  • June 17, 2025
Hello ​@Apoorva Gaur,
I understand you're facing an issue where your "Change to" interaction isn't triggering, even though you've set up your interactive components properly. That sounds frustrating!
I just quickly created an interactive component and added an instance to preview it on my end, and it seems to be working as expected.
To help us understand exactly what might be going on with your setup, could you please share a video recording or some screenshots demonstrating how you've set up the interaction and what you're currently seeing? This will really help our community figure out what's happening and how we can best assist you.
Also, you might have already checked these, but just in case, here are a couple of related guides that might be helpful for reference:
Apoorva Gaur
  • June 17, 2025
I'm experiencing an issue where setting the interaction to “After Delay → Change to [Variant]” results in no visible change—the component doesn't switch states at all. I've tested this across multiple components, variants, and frames, using different delay durations (e.g., 200ms, 1000ms), but it still doesn't work. Interestingly, other triggers like Hover and On Click work perfectly with the Change to action, so the problem seems specific to the “After Delay” trigger.
Apoorva Gaur
  • June 17, 2025
I did the same process for yellow rectangle using same values.
