Hey there, I’m running into library publishing failure and am hoping someone can offer a solution.
Context:
- The library is a design system file that has successfully published as recently as the afternoon fri, 2/28 (today is tue, 3/4)
The file memory usage is only 7%, and laptop has 50% available memory - The system contains atomic and simple molecular components with variant properties, and local variables for text and color
- I have triple checked the entire file for conflicting component properties and/or nested instances that might cause loops – it’s possible I missed something, but the library was publishing until a few days ago
- The last changes I made before publishing began to fail was to apply semantic color variables to icons
- however, I had successfully published updates with those variables to other components previously, so can’t imagine this is the culprit
- The file has 87 changes to publish, with 0 conflicting instances. Changes include modified, added, and removed components/variables
Error:
- When I attempt to publish, assembling components goes very quickly, but the “publishing library” flag shows for a anywhere from 10 - 25 minutes until eventually the “Publishing failed. Reload page to publish” flag shows
Troubleshooting:
- I have reloaded the file, restarted figma, logged out of and back into figma, and restarted the laptop
- Internet connection is fine
- I’ve tried with VPN both enabled and disabled
I’ve seen many posts about publishing errors, but haven’t found any solutions. So hoping someone here can help me 🤞🏻
Thanks figma fam!
