Cristian_Banu
Nov 5, 2024 1:30 PM UTC
Cannot cycle through screens
Hey guys,
When I preview screens, or even when I send screens to my clients for feedback, I usually have a row of screens and I cycle through them, in preview mode, using the left/right arrows, or the arrows in the bottom center of the preview view.
However, if I have a prototype in that page (2 or more screens linked with interactions), this feature seizes to function in the screens that are just regular screens, not prototypes.
Like if I have 30 screens which are not prototypes, so there are no interactions between them, after I hit PRESENT, I can simply cycle through those screens using the arrow keys.
As soon as I add an interaction between 2 screens, cycling between the rest of the screen, which don’t have any interactions between them, no longer works.
Is there a way to fix this?
Chris
Nellya
Power Member
Nov 5, 2024 2:42 PM UTC
Hi. When you add interactions between frames, you create new flow between them. Select starting frame and remove the flow to be able to see all frames in present mode.
Cristian_Banu
Nov 5, 2024 7:34 PM UTC
Hi Nellya,
Thank you so much for the response, it works. Makes absolutely no sense why it behaves like this, but it works 😂
