Can’t edit the text layer while double clicking the text layer, or any kind of text
INDU_YADAV
Double-clicking a text layer won’t let me edit it. The layer is not locked. This issue seemed to be resolved in past for other users, but the solution has not been mentioned in the thread. I am first time coming across this issue. Please guide.
Rithika
  • May 24, 2023
I’m having the same issue, please advice on how to resolve this
  • August 5, 2023
Me to…any help out there?
Hey Indu! Here are some troubleshooting steps:
  1. Layer Opacity: Ensure that the opacity of the text layer isn’t set to 0%. If it is, you won’t be able to see the text even if you’re in edit mode.
  2. Layer Visibility: Make sure the eye icon next to the text layer in the layers panel is not crossed out. If it is, the layer is hidden, and you might not be able to edit it.
  3. Nested Frames: The text layer might be inside multiple nested frames or groups. Sometimes, if there’s another layer or object on top of the text layer, it can prevent you from selecting the text layer. Try to isolate the text layer by moving other layers or objects out of the way.
  4. Masking: Check if the text layer is being used as a mask or is inside a mask group. If so, you might face difficulties editing it directly.
  5. Component Instances: If the text layer is part of a component instance, you might not be able to edit it directly. Instead, you’ll need to go to the main component (the master) to make changes.
  6. Plugins: Some plugins can interfere with Figma’s default behavior. If you have any plugins installed, try disabling them one by one to see if one of them is causing the issue.
  7. Browser or Desktop App: If you’re using Figma in a web browser, try switching to the Figma desktop app, or vice versa. Sometimes, browser extensions or issues can interfere with Figma’s functionality.
  8. Update Figma
  9. Restart
Avokadomos
  • Active Member
  • 377 replies
  • August 7, 2023
It will help if any of you can share the link to a design file where this problem occurs.
Sarah_Shuda
  • 5 replies
  • October 5, 2023
This is happening to me too. Very frustrating. The only workaround is selecting the text tool then editing the text. Double-clicking would be great though.
Marie_Lee
I just updated to Sonoma 14.0 and noticing this issue as well. Except it’s impacting all components, not just text
Hankai
  • 4 replies
  • October 18, 2023
I just updated to Sonoma , also happens this ,i think Figma has problem with Sonoma
I have the same issue. Did you find a solution @Sarah_Shuda ?
Sarah_Shuda
  • 5 replies
  • October 19, 2023
I’m on Ventura yet - so I’m not sure it’s the OS. I did not find a solution yet no. Please let me know if any of you do!
Sarah_Shuda
  • 5 replies
  • October 21, 2023
I found a solution. My problem was my Logitech Lift Mouse. I changed the speed of the double-clicking option to a slower setting and now I can magically edit text boxes in Figma. Could be worth looking at your mouse seeings with this issue?
I still have this problem, Checked mouse, trackpad and system settings. Also updated Figma. nothing got changed. 😭
Fernando_Lins
  • 44 replies
  • October 27, 2023
If you select the text layer and press Enter (PC) or Return (Mac) it will enter edit mode. This should be useful if you can’t enable editing by double-clicking for whatever reason.
thomas_bagnolati
same for me
I had a similar issue where I could use the Enter key and delete key, but not edit text in existing text boxes.
Oddly, I could create a new text box, type in it, but then not edit again afterwards…
I discovered (by a lot of trial and error and retracing my steps) that I have several keyboards installed on my Mac as I work in different languages. If I clicked to change language, suddenly the ability to type returned…
Heather_Harris
I’m having the same problem, but including items that are not text. I created the component, but now it will not let me resize or edit ANY elements, defeating the purpose of having made it a component. I can click on an icon, I can press enter or K or whatever and bring up the edit menu, but the edit menu is grayed out and I can’t click on or interact with any part of it at all. This is maddening.
Gayani_S
  • 1996 replies
  • March 19, 2024
Hey @Heather_Harris, thank you for reaching out! I totally understand that this must be frustrating, I am happy to help out.
Can you share us if there is any error message on your end? Is it happening in the browser, desktop app or both?
Can you clear out the cache. Here are some information to troubleshoot: https://help.figma.com/hc/en-us/articles/360040523973-Troubleshooting-checklist 1
Also please try to force-quit and open Figma in a new browser window (or force-quit the Figma Desktop app and restart it.)
To get this troubleshooting process started, can you make us a short video? Please include the whole window, with the properties and layers panels in view and relevant layers expanded, and select any layers you’re having trouble with so we can check any relevant settings. We use these videos to try and reproduce the issue in our own files and so showing all steps needed to reproduce the behavior is helpful.
Please also share your file link here or with me via DM with support-share@figma.com invited directly as an editor (this won’t affect your billing at all).
Thank you in advance!
Sheila_Sitaram
I also have this issue and it’s really cramping my style and my workflow - I’d love to see this resolved ASAP. I am going to update Chrome which might help, but a fix would be really useful. Thanks
Gayani_S
  • 1996 replies
  • March 26, 2024
Hey @Sheila_Sitaram, I understand that this issue is frustrating! Please let me know if updating your browser resolves the issue. Also please check if you have Chrome on the default configuration. Please also make sure you have the newest version of the operating system.
I can’t experience this in on my end, so I’d need a screen recording and further information to forward to the team to investigate further.
Thanks in advance!
TheoThien
I found a way to fix it. In “Mouse”, at “Double-click”, don’t drag the slider all the way , decrease it one notch and return to the left.
Just drag the slider full , and your Macbook will automatically disable the double-click feature to select objects or select text in all apps or elsewhere .
I’m using Sonoma version 14.4.1.
Andrea_Cadena
this saved my sanity, thank you!!
  • June 12, 2024
It is still happening on 2024 with Monterey… but your tip about reducing that setting on the mouse worked for me… It is a problem with Figma that they should fix…
Amico
  • October 11, 2024
I was having the same issue and then realized the Dropbox folder that was hosting the fonts was not syncing which caused the Typeface app to not load them… and for some reason Figma did not send the standard error that usually does when missing fonts!
Once I synced the fonts folder properly everything went back to normal!
Li_Li1
  • November 8, 2024
I have the same issue after switching to a new Mac with Ventura. I’m using an older magic mouse, and there’s no double click option in setting. I also found: “triple-click” works every time.
Maybe somehow my Figma registers the “double-click” after a first click?
Curious if “triple-click” also works for other people.
alexznicholson
Experiencing exactly the same issue. Double click not working on desktop Figma app. Neither is press Enter to edit text.
Both work in browser editor, but not on desktop app.
Running:
Figma 124.6.5
Mac OS Catalina 10.15.7
Using trackpad, not mouse.
Extremely frustrating that one of the core features of the app doesn’t work straight out of the box. What’s going on?
ksn
  • 1646 replies
  • January 14, 2025
Hey ​@alexznicholson - I tried replicating this on my end, but I seem to be able to double-click on trackpad and wireless mouse to edit the text. I can also hit enter/return to edit text as well.
However, I am on a different OS than you, so I’m not sure if that could play a role. For yourself individually: are you seeing this behavior across all files you try to work on, or does it only seem to be specific ones? Does it only seem to be in only specific text boxes on certain pages, or just all of them? I can look into this more -- if I can get more of those details, that would be helpful.
