Plugin : Non Null Origin iFrame
  • April 17, 2025
  • 59 views
DanDoesDesign
Hey there, I’m looking for help setting up the UI for a Figma plugin.
I am using a non-null origin, and testing the code using “https://www.google.com”
figma.showUI(
  `<script>
    window.location.href = "https://www.google.com";
    console.log(window.origin); //null
  </script>`,
  { height: 600, width: 400 }
I’ve included google in the manifest as an allowed domain.
  "networkAccess": {
    "allowedDomains": ["https://www.google.com",
      "https://*.google.com"
    "reasoning" : "For testing purposes",
    "devAllowedDomains": [
      "https://wwww.google.com",
All I see in the plugin window is a white box. The console isn’t throwing any syntax or permission errors.
Does anyone have a suggested fix? Is there something “basic” that I’m missing? (like, not testing showUI with google)
Thank you for your time.
reynaldi
  • April 24, 2025
Your snippet for loading a non-null origin is already correct, by using the window.location.href. However, it’s Google that is preventing you from loading it in an iframe.
Google is using the `X-Frame-Options: SAMEORIGIN` header, which means it can only be loaded inside an iframe in a same origin (meaning only google.com can load an iframe of google.com).
Just try it immediately using your actual UI, and you should be good.
