Issue with displaying hidden areas using variables (all contents within hidden area don't display)
Rob_Tranter
Hi,
I’ve recently come across what I believe is a bug in Figma when prototyping and switching the appearance of hidden areas within the design on and off using a boolean appearance switcher. Areas within the hidden sections are now also hidden intermittently. These areas were all working previously across the whole prototype.
Has anybody else had a similar issue recently with nested layers not displaying when the container layer is being switched on and off using a boolean on/off switcher within a prototype?
Mohit Mishra
I am also facing same issue since one and half hour.
Rob_Tranter
Thanks for confirming you also have the issue ​@Mohit Mishra . Hopefully it’s fixed soon as currently large chunks of my prototype are broken and there’s a client playback shortly.
Mohit Mishra
@Rob_Tranter this issue has been resolved now. Can you confirm the same?
Rob_Tranter
Ah yes, I can confirm that it appears to be fixed now ​@Mohit Mishra  🙂
