Component text property with 2+ local variables fill breaks on theme mode change
  • January 18, 2025
  • 10 views
Bruno12
Explanation
When creating a component, with variable text as a property and filling its text with 2+ token variables (with 2+ modes) sourced from “local variables”.
Instances with text variants (different text content) break on a “local variables” mode change, resetting its text content to the component property default & forcing it to stay that way (unable to change)
Replicate
  1. Create 2 local variable with 2 modes
  2. Create a component with text (text content as a proeprty of Component)
  3. Make text from component have different colors sourced from variable of step 1
  4. Create an instance and change its text content
  5. Change variable mode (at instance “Appearance” design section)
  6. Text Content gets resetted to orginal component default property & its unable to change
Example
https://www.figma.com/design/tBYI0u0lAzgFgY4Jnq8pzV/Bug-Component-Prop-Not-Working-When-Colored?node-id=0-1&t=qxAitZaSH7YwaxRy-1
  • 2355 replies
  • January 21, 2025
Thanks for reaching out. I think I could replicate this behavior, and I'm checking if this is a feature limitation or a unexpected behavior with our internal team .  I will get back to you when I have anything I can share with you.
Thanks for your patience.
