The Instance text doesn't reflect Component changes
  • January 14, 2025
  • 7 replies
  • 216 views
ahmadfawaid
Sorry, the title is wrong. I can’t update it.
I have a problem where the text in the component and its instances doesn’t update when I change the font weight in the text styles.
styles does not update to reflect changes made to the component.
Steps:
- I created a button component, and the text in the button uses text styles
- The font in the text styles is linked to a variable
Issue:
When I change the font weight in the text styles, the button text in both the component and its instances doesn’t update.
Note: this issue only happen when the font is linked to a variable.
Figma file here
  • 2422 replies
  • January 14, 2025
Thanks for reaching out. I'm checking with our internal team. I think I could reproduce the issue, so I passed this along with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
ahmadfawaid
  • 15 replies
  • January 15, 2025
y_toku wrote:
Thank you for the feedback. I hope it gets fixed soon, as many of us are using variables for the font name
waqarnaik
  • 21 replies
  • January 15, 2025
Yes same issue im facing variants text weights are not updating in realtime
waqarnaik
  • 21 replies
  • January 16, 2025
@ahmadfawaid is this revolved? Im also tired of this bug our team using variables and they are kind of stuck on project
ahmadfawaid
  • 15 replies
  • January 17, 2025
@waqarnaik sadly, not yet
  • 2422 replies
  • January 20, 2025
Hey ​@ahmadfawaid ​@waqarnaik
Sorry for keeping you wait. Our engineering team released a fix, so could you reload a tab and check?
Please let me know if the issue persists!
Thanks again for your patience.
ahmadfawaid
  • 15 replies
  • January 20, 2025
@y_toku cool thank you for the updates! but, I got another issue. When I detach the text styles in the component (the text styles using Variable font) and change the font weight, the instance doesn’t reflect the update.
Before detach
After detached
