Hi all,
Need some help with the age old problem of Sofia Pro not showing the correct font weight when the Inspect panel is open. In this example, semibold has been applied but in the Inspect panel it shows as font-weight:400; for all weights.
It’s causing additional back and forth between developers when reviewing components while they are technically following the designs and the information in Figma… except it’s the wrong font weight :(
I have seen some other threads that have been opened in the past but was wondering if someone had a newer solution to fix this.
Are my only options to solve this problem still:
- Ask developers to refer to the name ‘H6/D Semi Bold’ for the right font weight?
- Edit the metadata?
Thanks in advance!
