Why is they purple and how do I get rid of it?
  • April 26, 2023
  • 4 replies
  • 10224 views
Best answer by Celine_
Hi @Almas_Hamzat ,
Your objects in your left side bar are in purple because they are under the Component
Capture d’écran 2023-04-28 à 16.07.02
  • 3662 replies
  • April 28, 2023
Hi @Almas_Hamzat ,
Shubh_Aggarwal
What does it mean being under the component?
  • February 26, 2024
To ungroup elements, you can select the group in the Layers panel and use the command “Ctrl + Cmd + G” on Mac or “Ctrl + Alt + G” on Windows. Alternatively, you can choose “Object” in the top menu and select “Ungroup.”
  • 2545 replies
  • February 27, 2024
Components are elements you can reuse across your designs. They help to create and manage consistent designs across projects.
You can create components from any layers or objects you’ve designed. These could be a whole range of things like buttons, icons, layouts, and more.
You can grasp overview of Components
Please check out the help center article:
Figma Learn - Help Center
Hope it helps!
Toku
