Jason_Sparks1
Why can't I see any styleIds in my fills even though they are using color styles?
  • October 21, 2023
  • 9 replies
  • 704 views
I want to write a plugin that checks every layer within a component to ensure it’s using colour styles. My component has some layers using local colour styles and other layers using colour styles that come from a published library.
I can traverse nodes and have this bit of code inside my node traverse function.
function traverse(node: any) {
      if ('fills' in node && node.fills) {
          for (const fill of node.fills) {
console.log(fill, fill.paint, fill.styleId, fill.style)
but there is no paint, styleId or style on my fills. The property doesn’t seem to exist.
At the top of my code I have const paintStyles = Figma.getLocalPaintStyles() and when I console log that I see an array of 3 items which is what I expected…that is how many styles are being used in the component.
But why am I not able to access style or styleId? Is this something to do with async behaviour and the style info not having loaded at the point of console.log?
tank666
October 21, 2023
node.fillStyleId
Please see the developer documentation:
figma.com
Jason_Sparks1
Thanks for the reply but I had read the documentation before I posted the question. The issue is there are no styleIds associated with any of my nodes even though the Frame nodes and Text nodes are using local and published library styles. That is what I don’t understand. Any ideas?
tank666
October 22, 2023
What does it mean? Have you checked the fillStyleId property of the node?
Fill does not have such properties. Where did you get them from?
Jason_Sparks1
All node.styleId values are undefined. If I console.log(node) I just get e.g. FrameNode {id: “154:132”}.
tank666
October 22, 2023
Could you share the link to the test design file?
Jason_Sparks1
Sure, thanks for looking at this. Let me know if you want me to change the permissions to edit. https://www.figma.com/file/IMPeLFpbuLC6nWlE9U47Fy/Plug-In-Research?type=design&node-id=4%3A7&mode=design&t=dq3h1Oy1CY5wuCK1-1
tank666
October 22, 2023
All your objects have a color style applied and the fillStyleId property contains a value.
frame-14
frame-15
text
Jason_Sparks1
That is so odd. I am not seeing that. See here:
How are you seeing those properties - via a console.log(node)?
The only difference was the file I shared with you was my personal/free Figma account which doesn’t have access to the development option. The same Frame is copied in my work Figma account and the screenshot shows what is being output when I console.log(node). It’s not to do with permissions on my work account is it?
tank666
October 22, 2023
Click on the (…) next to the property to get the value.
Please check out this article:
figma.com
