Robert48
Jan 22, 2025 10:11 AM UTC
Where did target multiple variable in conditionals go?
Conditional prototyping used to allow us to
  1. IF statement - allow to set multiple variables ( var1=”A” && var2=”A”)
  2. THEN (set variable) - change variable (var1=”B” && var2=”B”)
    1. ☝️ This doesn’t seem to be supported in the new UI. You can only explicitly declare 1 variable
What happened to 2.1, is this no longer supported? Or is there a new work around with the new UI?
Ideally, I want to be able to change multiple variable’s value from a click condition. This used to be possible in the previous UI because we can write the script. What am I missing? 🙆‍♂️
