Aatir
Oct 3, 2024 11:05 AM UTC
When we run prototype with no device, the whole frame is not responsive?
Here Header is fill container and elements inside are also behave with size.
All the other sections aligns with header with same responsive style.
Still why the white space in present mode??
Aatir
AatirAuthor
Oct 3, 2024 4:54 PM UTC
Structure as below :
Homepage [Top Most Frame - width : 1920px - proto - responsive]
Header [width - fill container]
Section [width - fill container]
… same as above [no section is larger than header]
Why homepage frame (top most / parent frame) has white space to it’s right in proto (present mode) - no device??
Luke-Itineris
Oct 4, 2024 9:48 AM UTC
Can you share a proto link please?
Aatir
AatirAuthor
Oct 4, 2024 10:56 AM UTC
Link
Figma – 4 Oct 24
Please recheck that scaliing is set to responsive. If it’s responsive, shouldn’t homepage resize to the viewport available? Coz inner frames ‘header’, ‘section’ did became responsive to viewport.
Luke-Itineris
Oct 4, 2024 11:05 AM UTC
Im not sure what you mean. The page frame is responding. What else do you want it to do?
Aatir
AatirAuthor
Oct 7, 2024 12:03 AM UTC
Now scroll this proto horizontally. Do you see the white space? If not, increase the size of page to 2x or 4x then do the same.
My issue is why the page frame has white space to it’s right when scrolled horizontally in present mode?
rwb_marns
Oct 7, 2024 1:41 AM UTC
As per checking with your link, it seems working perfectly fine. If it has issues on your end, it might good if you share your layering structure.
On top of that, we can make the frame responsive with or without device.
Luke-Itineris
Oct 7, 2024 8:04 AM UTC
I still can’t replicate your issue.
Aatir
AatirAuthor
Oct 7, 2024 12:08 PM UTC
Use mouse button to drag the whole frame to left.
Attaching video link as new user cannot upload attachments.
drive.google.com
Luke-Itineris
Oct 7, 2024 3:21 PM UTC
Yes, this is a bug. You need to report it.
Oct 8, 2024 4:51 AM UTC
Hi @Aatir ,
Could you file a bug report from here?
Figma Learn - Help Center
Toku
