Video playback is dysfunctional in Figma Slides
  • November 15, 2024
  • 7 replies
  • 125 views
Andrew49
I have placed multiple video files (.mov and .mpeg4) into a Figma slide, and de-actived “autoplay.” When viewing the slide in presentation mode (either standard view or full screen), the videos do not play when clicked. If I skip to the next slide, then return to the slide with the videos, they play as expected.
Major bug, not new, must have feature… please fix it.
Mike_Taku
Hi there, I hope you are doing well. As far as I know, when you are placing videos in Figma slides with autoplay disabled, they don’t play on click in presentation mode unless the slide is revisited.
This disrupts presentations and feels like a significant bug. Fixing this would greatly improve user experience and video functionality.
Thank you,
Mike Taku.
RFH
  • January 31, 2025
Yes, same experience here - this is a major bug and showstopper for us.
Tal Klein
  • February 16, 2025
same here. i would also expect that if there is a file size limitations then any file smaller than 100mb should play properly, but no. It even slows down one of my videos, i’m saying this because it doesnt have the original run-time, but a longer one.
On the other hand - on present mode with regular design file prototypes they load and play straight away just fine.
  • February 18, 2025
Hi ​@RFH ​@Tal Klein
Thanks for raising this. Since I couldn’t reproduce this issue on my end, would you be able to share the screen recording please? Hope to investigate this further.
Thanks for your patience.
Toku
Metanoic Vision
Same bug on my side
Happened to me twice at an important presentation and needed to skip the video :(
Only happens if “present + notes” is enabled.
  • February 19, 2025
Hi ​@Metanoic Vision
Thanks for sharing the details! I could reproduce this issue in the “Present + Notes”, so I shared this issue with our internal team.
I will get back to you when I have anything I can share with you.
Thanks for your patience!
Toku
RFH
  • February 20, 2025
Hi ​@y_toku ,
I will DM you with a screen recording.
Thanks - Christoph
