Hi, Hirak.
Based on your layers, the change to is disabled because there is nothing to change to because it’s not a variant. Also, you merged all the possible variants into 1 component.
What you need to do is to make frame 1, 2, 3, and 4 into a component and then combine them as variants.
After that, the change to property will be enabled when you will prototype its instance.
