Massimo.Fiorentino
Jul 8, 2024 8:58 AM UTC
Truncate text: Not changeable when turned into style?
Hello all,
Is it true that you cannot change the settings for truncation whenever your text properties have been saved as a style? If you, by accident via copy-paste, inherit truncation from some text and then turn this into a style, you cannot find any property for this under its settings afterwards.
It seems a tad cumbersome if you then need to recreate the text style and go through your entire prototype to re-apply the new style afterwards.
Cheers,
Massimo
Massimo.Fiorentino
Jul 8, 2024 9:29 AM UTC
FYI: A partial solution is to select the text on any element using the style, then uncheck “Truncate text”, but this doesn’t change it at the Style level.
