VictoriaHelen
Aug 18, 2024 10:40 PM UTC
Trouble changing states between variants (solved)
This is a super basic question but I can’t seem to crack it.
I decided to make my own checkbox because the one I was using in the community wasn’t working for what I need (basically wanted to create master component but it kept getting kicked out because it’s a widget not a component instance).
I created my 2 variants (on, off) following a tutorial I found on youtube, and when I went to test it, nothing happened which was unexpected.
I’ve searched high and low and reworked it 20 different times and I can’t figure out why my checkbox won’t change on click.
Figma – 18 Aug 24
Raphael_M
Power Member
Aug 19, 2024 1:23 AM UTC
Hi. Your component works fine. I just replaced it using the component you’ve made.
VictoriaHelen
Aug 19, 2024 1:30 AM UTC
Hi Raphael, thank you! It works on my side now. A bit embarrassing it was simple, but I’m glad it works so I can continue my project
