Karina_Elias
Oct 10, 2023 6:45 PM UTC
Text Tool not working
When I use the text tool I do not get the ‘text box’ which allows for resizing and I am not able to put the cursor inside the text phrase to make changes. This is a basic functionality. How can I fix this?
Karina_Elias
Karina_EliasSolution
Oct 10, 2023 8:50 PM UTC
Had nothing to do with the browser or extensions. Basically, I spent an hour researching online to figure out that if your line height set to 0, which it does by default, then you cannot get a text box.
Ryan_52
Technical Quality Specialist
Oct 10, 2023 7:06 PM UTC
Hi @Karina_Elias I tested this from my end in both the browser and desktop app but was able to add a text box and text without issues. Are you see this in the browser? If you have any browser extensions enabled, try and disabling them to see if that helps. I would also suggest trying to clear your cache in the browser or desktop app.
Karina_Elias
Karina_EliasAuthorSolution
Oct 11, 2023 2:41 PM UTC
I did to. When I type nothing shows up on the canvas but a very small blinking dot.
Nothing like what you see happening in any tutorial. Where they click and type.
Is that what is happening with you? did you find a solution?
Oct 11, 2023 2:43 PM UTC
Shivani_Rawat
Apr 19, 2024 5:13 AM UTC
I am not getting a text box after tapping the text icon
Instead of text box i am getting a blinking dot
What to do?
Apr 22, 2024 1:14 AM UTC
Hey there, I tested on my end and it works fine. Do you still have this issue?
Here are some actions you can take to improve performance:
I hope it works but if the issue isn’t solved, can you share the screen recording?
Toku
