Jairo
Jul 1, 2023 7:31 AM UTC
Stroke to scale with the object
HI! just noticed that when i upscale an object with a stroke applied to it. the stroke maintains its width.
Is there a way for the stroke to scale with the object? (Just like in Illustrator)
Using Scale tool not an option, as it indeed scales up the width of the object, but when dealing idth icons, as soon as you swap an instance, the new instance reverts back to original width.
Thanks in advance
Vazgen
Dec 5, 2023 3:46 PM UTC
Hey @Jairo, had the same issue with the icons. Unfortunately Figma doesn’t have the same functionality of scaling strokes similar to the illustrator.
But found a workaround by outlining the stroke of the initial icon. In these way, even if the instances are very small, the icon stroke will stay the same.
I hope this helps.
Pavlo3
Oct 9, 2024 9:37 AM UTC
Hi @Jairo, for fixing this issue you can convert stroked lines to stroke outline like in this tutorial
Figma Learn - Help Center
It converts line to shape and you can scale you SVG properly 😉
Alexey Orlov
Mar 5, 2025 8:13 AM UTC
How to scale proportionally in Figma?
Scale layers while maintaining proportions – Figma Learn ...
Scale
  1. Activate the scale tool by pressing K , or by clicking in the toolbar and selecting Scale.
  2. Select an object.
  3. Scale the object by doing one of the following: Click and drag: Hover over the object's bounding box to make the cursor appear. Then, click-and-drag to resize.
Steve Che
Jul 18, 2025 5:35 AM UTC
Scale
What if I want to scale the outline of a nested instance? It is currently impossible for the outline of a nested component to size proportionally with its parent frame inside another component.
P/s: I cannot convert the ellipse to SVG since I want to maintain edit function for the sweep of each legend.
