Jan 19, 2024 9:00 AM UTC
Splash page not showing when linked
I am having trouble with my hi-fid prototype. The flow begins with a couple of frames for the splash page. When I view it in presentation mode it works fine. However, when I link it on my Behance project, it skips the entire splash presentation. Help!
Gayani_S
Jan 19, 2024 10:31 AM UTC
Hey Immanuel, would you be able to share a screen recording with me? I am not sure if this is happening because of the platform Behance.
Jan 28, 2024 8:18 PM UTC
Hi
How shall I send the recording to you?
Gayani_S
Jan 30, 2024 10:18 AM UTC
Hey there, I’ve send you a DM, so feel free to share this via DM or here under this post.
Feb 21, 2024 10:04 PM UTC
I am also have the exact problem but I have my link on my website and it also skips the flash page.
Gayani_S
Feb 23, 2024 4:37 PM UTC
Hey @lisette_kelmanson, thank you for reaching out!
Could you please confirm if you have to make any interaction on your page?
Can you try viewing it on different browsers?
This might be happening because you can only view file embeds. There is no way to select individual layers or make any edits to the file. More information you can find here: Interact with embeds.
Also, let me ask internally to double-check with the the team as well. I’ll get back to you once I’ll receive a response.
Gayani_S
Feb 26, 2024 5:30 PM UTC
Hey @Immanuel_Jaeggi, can you confirm if you’ve embedded a link directly to a specific frame or if you’ve linked it to the overall file?
Also, please confirm that you’re embedding URLs that look like https://www.figma.com/file/LKQ4FJ4bTnCSjedbRpk931/Sample-File and not like https://www.figma.com/file/LKQ4FJ4bTnCSjedbRpk931/Sample-File?node-id=1-497?
Thank you in advance!
Feb 28, 2024 1:14 AM UTC
Hi Gayani,
Here is the link to my Figma file where it does not load the splash frames on my portfolio site. Thanks in advance
Figma – 26 Sep 23
figajm
Mar 1, 2024 3:51 PM UTC
Hi @lisette_kelmanson! Looking at the link you shared:
https://www.figma.com/proto/yIiZRH4E26IByiqWxxWs42/G%2BT-(Give-%2B-Take)?type=design&node-id=1015-4959&t=GUgH6EiSjS30LNKo-1&scaling=scale-down&page-id=645%3A1554&starting-point-node-id=1096%3A7691&mode=design
The presence of all the stuff after the ? is telling Figma where you’d like the prototype to start. It’s likely that you had a particular frame selected when you copied the URL, which caused Figma to add that node to the URL (under the assumption that you wanted the prototype to start on your selection).
You can remedy this by removing everything after the ? when you put the URL into Behance: https://www.figma.com/proto/yIiZRH4E26IByiqWxxWs42/G%2BT-(Give-%2B-Take)
Mar 5, 2024 4:34 PM UTC
Thanks Figajm,
Taking out the “?” from the link worked and my splash page starts at the link. Thanks a bunch.
Keoca_Maoec
Dec 4, 2024 10:48 AM UTC
Thank you for bringing this issue to our attention. It seems like the splash page isn’t showing up as expected when linked. This might be related to certain configuration settings or an issue with the implementation of the splash screen. For more details on why splash screens might not be working or best practices for integrating them into your app, you can refer to this article: https://www.cleveroad.com/blog/mobile-app-splash-screen-reasons-to-integrate-launch-screen-into-your-app/.
