Show/hide elements onclick if checkboxes are checked
  • January 23, 2024
  • 9 replies
  • 4412 views
Paul_Harvey
Hi, I’m pretty new to Figma and need some help please. 🙏
I’m trying to create a prototype that has multiple checkboxes independently relating to different areas/regions that if when a “view” button is clicked all of those that are checked/true show and those that aren’t hide. I have set up all checkboxes as true, and have given each a separate name. I have also added conditionals to the view button that’s
-onclick if “xxx” checkbox is true,set variable show “xxx” region to true
else set variable “”region” to false.
Hope that’s all clear to understand. Any advice? Thanks
  • 2545 replies
  • January 24, 2024
Hi there,
hanks for reaching out! Your approach sounds solid. I’ve come across a community resource that might be really helpful for you: https://www.figma.com/community/file/1256660046319231869/interactive-variables-components-radio-button-select-all-check-boxes-dropdown-and-accordion?searchSessionId=lrsew3bu-oxsv22swrml.
This resource covers prototype settings related to checkbox actions. I believe you could apply the same logic to your project.
I hope this is useful, but if you have any more questions, please don’t hesitate to ask. I’m here to help!
Toku
Paul_Harvey
Hi, thank you for replying. I took a look at that but that’s not really what I was looking for. I am having issues with the interactions being nested I think… not sure. What I am trying to solve is that when a checkbox is checked (on click), another element is shown, when it’s not checked it is hidden. I can get it to work in one direction but the checkbox doesn’t seem to change back. Is this due to its nesting? Currently, i have the interaction as on click and change to for the checkbox but alas this isnt working. Any other advice? Thanks in advance.
  • 2545 replies
  • February 15, 2024
Hi there,
I apologize for the delay in following up. If you have not yet found a solution, could you possibly provide us with the file link so that we can investigate?
Toku
AlicePackard
  • Active Member
  • 194 replies
  • February 15, 2024
I just submitted a bug report for a very similar issue today! In my case it’s a series of mega menus hidden in a global navigation. I’m using the same logic as you. An extra problem I’m experiencing is that my text overrides are being lost on click.
I’ll report back here with what I hear from Figma support.
Darcy_Branchini
Did anyone find a solution to this? I’m also trying to do this, but failing.
Shaul_Vainblat
@Paul_Harvey you can show/hide elements by creating a boolean that is applied on what you want to hide/show.
For the checkbox, i created the states(unchecked/checked), and for each variant state i gave an interaction to change to state and change the boolean so the elements will hide/show.
When you place the variable interactions on the the checkbox states, you make sure each state does what it needs to do.
Andrew_Mowe
  • 6 replies
  • September 25, 2024
I’m trying to do this exact same thing, but I’m not sure how you’re able to apply a variable to a Layer boolean property in the first screenshot. Can you explain how to do that?
Shaul_Vainblat
@Andrew_Mowe use the “eye” icon of the layer section, right click on it and select a boolean to apply, from that point the boolean will control the visibility of the layer
Alamaki
  • 48 replies
  • October 1, 2024
A cludge solutio I have been using is placing a seleted checkbox on top of an unseletected one. The top one being visible only when a boolean foo is true, and an onClick “set variable” action doing “foo = not foo”. That gives me is a boolean variable foo and a checkbox that views and controls it’s state.
Sounds like your case could use the same for all the checkboxes, e.g. checkboxes controlling boolean variables foo, bar and baz. The “view”-button could then have onClick “set variable” actions setting some booleans e.g. “panelFooVisible = foo” and “panelBarVisible = bar”. That way the checkboxes don’t directly control visiblity and changes happen only after “view” is clicked.
