Responsive square images
  • December 22, 2023
  • 920 views
I have created a card that contains a square image, a product title and a price. I’m using a frame to contain them all and auto layout to keep the text in place. I want to know if there is a way to ensure that the square image stays square when responsively resized?
Best answer by Rachael_Raghuram
Hi Kim, Thank you for your reply. Appreciate your help with this, it’s been driving me bonkers! I want the image to dynamically change, but it must remain in its square format. I don’t want the image to become rectangular in anyway – which is what seems to be happening.
For example, I have created a product card for a category page. Dropbox - Unknown-2.png - Simplify your life
When I increase the size of the overall card (holding down shift and dragging the bottom right corner handle) I’ve set the constraints up to resize the objects accordingly, but the image doesn’t not maintain its square ratio. Is there a way to do this?
Many thanks,
Rachael
ksn
  • December 26, 2023
Hey @Rachael_Raghuram – if I understood your question correctly, you’re have text and an image in a frame. You have the frame set with auto-layout to keep your text where you’ve set it, but you also want the image you have to dynamically change in size if you adjust the size of the frame.
If that’s the case, you’d want constraints on the image so it adjusts in size dynamically. HOWEVER, it’s not possible to apply constraints to layers outside of a frame, or layers in an auto layout frame, so the image will not be able to perform this behavior.
Let me know if I misunderstood. See here for more info on constraints: https://help.figma.com/hc/en-us/articles/360039957734-Apply-constraints-to-define-how-layers-resize#apply
Many thanks,
Rachael
ksn
  • January 12, 2024
hey! Sorry this is such a late response, but I checked in with the support team, and it sounds like you’re looking for a locked aspect ratio. This isn’t currently available in the platform‌, but this plugin may help: https://www.figma.com/community/plugin/1234709595094737890
lemme know if I misunderstood.
