Resize Autolayout Layer
Hello friends,
Odd question I know, but I have a table and I would like to make my columns larger by resizing the different “autolayout layers” larger, but only towards the right.
Currently, when I try to do this using the mouse or by enter a fixed value, the layer increases proportionally in size both to the left and the right.
Is there a way to increase only towards the right?
Thank you.
Best answer by mo_hamwi
after reviewing your file I saw that you made the auto layout aligned to the bottom center
Screenshot 2024-01-31 at 1.46.37 PM
Changing it to the bottom left Will solve your issue
Screenshot 2024-01-31 at 1.47.27 PM
Also the reason that it’s working on Column2 because you made the text inside as a boxed text
Screenshot 2024-01-31 at 1.49.08 PM
Changing it to auto width as shown below you will face the same issue
Screenshot 2024-01-31 at 1.49.32 PM
I suggest you to look out for more tutorials on auto layout to help you understand the fundamental, I will attach a file with problem solved to get you a better idea of what going on
Auto layout resize expanding to both the left and right.fig (35.1 KB)
I removed the auto layout layers and increasing the width to the right on the text layer itself seems to work.
I’m still curious if this is possible with a layer that has an auto layout applied.
mo_hamwi
  • Active Member
  • January 23, 2024
can you share screenshots or the file ?
Thank you - please see attached file. I included an example of the issue I am having.
Auto layout resize expanding to both the left and right.fig (36.0 KB)
mo_hamwi
  • Active Member
  • January 31, 2024
Thank you!
mo_hamwi
  • Active Member
  • February 6, 2024
you’re welcome, if that was useful and solved you problem please kindly mark it as a solution, thank you
